Zobraziť témy bez odpovede | Zobraziť aktívne témy Aktuálny čas je Pon, 02.11.2026, 20:32
 Uzávierka
Registrovaný: Pon, 28.02.2011, 19:01
Prosím má niekto skúsenosť s uzávierkou diferenciálu - Lockright 1510 na Suzuki Jimny na zadnú nápravu?
http://www.spidertrax.com/s.nl/it.A/id.627/.f
Pon, 28.02.2011, 19:05
Absolutne sa nehodí na zadnú nápravu. Dopredu áno.
Pon, 28.02.2011, 19:34
Registrovaný: Pon, 05.02.2007, 17:09
Maš to vyskúšané osobne, alebo JPP ?( jedna pani povedala)
Netvrdím opak. Ja by som to nedal ani do predu.
Pon, 28.02.2011, 19:52
Jediné čo som k tomu kedy našiel napísané je toto:
http://www.jimny.se/phpbb/viewtopic.php?t=1640
"VVT series' diff is absolutely identical to any other diff as far as Lockrite installation is concerned. I have installed hundreds of Lokrights 1510 over the last 2 years. If you are running AT gearbox, LR 1510 in the rear is your ideal choice. If you have MT gearbox, I would only recommend it as a much cheaper alternative to ARB. It will block the wheels at cornering occasionally and might be a nuisance. You will never get any of these symptoms with AT gearbox. If you need an autolocker in the front, I would recommend you look at APIO LSD. It is a very capable device, when it comes to breaking front axleshafts and CV joints. I could not park a Jimny with ApIO LSD in the front and only one freewheeling hub engaged. The car would keep driving to one side, no matter how hard I steered. With the second hub engaged, steering went back to normal for steering with LSD. Easy to install, very reliable. I have LR 1510 in the rear and ARB RD 118 in the front. DG tuning HD axleshafts."
Z toho som pochopil že by to snáď mohlo byť vhodné na zadnú nápravu....ale hľadám niekoho s osobnou skúsenosťou u nás.
Uto, 01.03.2011, 9:18
cela pointa je v tom, ze vsetky automaticke uzavierky bez rozdielu maju spolocneho menovatela : nevies to vypnut...
kedysi v statoch to bolo primarne vymyslene pre supersportove auta na zlepsenie startu a jednoduchsie driftovanie...
cize modelova situacia : manzelke to pozicias na nakup a je akurat -3 st zima, posmoklena cesta, v zatacke sa nedokaze pri takej malej adhezii racna pretocit a tym padom zaberaju obe kolesa, manzelka si popiskuje a kludne vojde do zatacky, ma pocit bezpecia a drzi kontinualne primerany plyn = a zrazu prdel auticka urobi sup do boku a manzelka je v priekope
Uto, 01.03.2011, 9:40
Proviantak
hmmm a co vajca v tescotaske?? ako su tie na tom??
Uto, 01.03.2011, 11:01
[quote="Jaro KE"]Maš to vyskúšané osobne, alebo JPP ?( jedna pani povedala)
Vzadu to odskúšané nemám, lebo sa nerád učím na svojich chybách.
Uto, 01.03.2011, 11:33
Pejo,mudro vravis :D ,treba si poriadne precitat co napisal Radoof,poriadne si nastudovat ako funguje ausina a potom kazdy pochopi,ze dat to dozau na kratke suzuki je blbost.Potom uz lem musime cakat,ze si to niekto naozaj namonti dozadu,ale myslim ze sa urcite nepochvali ako dopadol :-D
Uto, 01.03.2011, 17:37
Registrovaný: Pon, 07.12.2009, 19:22
ja ju mám v predu už asi 3 roky a funguje to v pohode akurát je kus vačší polomer otáčania ked je zapnutý predok.
Uto, 01.03.2011, 21:10
Aj s tým sa dá vypiecť, treba v oblúku krátko ubrať, preklopí sa čap a predné vnútorné koleso pribrzdí. Vonkajšie koleso rechtačka uvoľní. Auto sa poslušne natočí a potom sa dá pridať.
Str, 02.03.2011, 21:17
dandysd: máš presne toto na Jimnym vpredu ? Resp. čo presne máš? Si spokojný?
Pon, 07.03.2011, 12:23
Registrovaný: Ned, 12.12.2010, 21:55
Idem na mojho sama robit zadnu mechanicku 100% uzavierku,ktora dost znesie a nemala by sa rosypat ani pri vacsej namahe.
Tak ak bude dosst materialu mozem spravit aj viac kusov podla zaujmu.
Zatial mam material na 3 kusy no tie su uz zadane.
Tak ak by niekto chcel neni problem spravit.Samozrejme napravu musite dorucit kumne.
SAM 413 ex PATROL K160 SD33 v stadiu uprav PATROL GR Y61 ZD30
Str, 09.03.2011, 17:09
nejake detaily? to nieje ako vyrabat naraznik :) ale to asi vies, ked sa do toho pustas
Str, 09.03.2011, 18:49
Výr píše:
mám lockright locker 1510 v predu na samurai. som spokojný, treba sa s tým naučit jazdit
Ned, 13.03.2011, 18:10
