Zobraziť témy bez odpovede | Zobraziť aktívne témy Aktuálny čas je Str, 18.11.2026, 13:43
 top gear Botswana special
Registrovaný: Str, 07.05.2008, 8:05
Botswana special
Obrázok Obrázok
General
Format : AVI
Format/Info : Audio Video Interleave
File size : 695 MiB
Duration : 59mn 33s
Overall bit rate : 1 633 Kbps
Writing application : Nandub v1.0rc2
Writing library : Nandub build 1852/release
Video #0
Format : MPEG-4 Visual
Format profile : AdvancedSimple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 59mn 33s
Bit rate : 1 490 Kbps
Width : 640 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.265
Stream size : 635 MiB (91%)
Writing library : XviD 1.1.0 (UTC 2005-11-22)
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 59mn 33s
Bit rate mode : Variable
Bit rate : 130 Kbps
Nominal bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 55.2 MiB (8%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.60 video frame)
Interleave, preload duration : 479 ms
Writing library : LAME3.90.
Encoding settings : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
Kód:
http://www.fileserve.com/file/z4cyqyG/Top.Gear.S10E04.WS.PDTV.XviD-RiVER.part1.rar
http://www.fileserve.com/file/syu6MEZ/Top.Gear.S10E04.WS.PDTV.XviD-RiVER.part2.rar
http://www.fileserve.com/file/m8YsRTu/Top.Gear.S10E04.WS.PDTV.XviD-RiVER.part3.rar
http://www.fileserve.com/file/BvhHyxy/Top.Gear.S10E04.WS.PDTV.XviD-RiVER.part4.rar
http://www.fileserve.com/file/GMkbueK/Top.Gear.S10E04.WS.PDTV.XviD-RiVER.part5.rar
http://www.fileserve.com/file/G5j6adn/Top.Gear.S10E04.WS.PDTV.XviD-RiVER.part6.rar
http://www.fileserve.com/file/nNBKHva/Top.Gear.S10E04.WS.PDTV.XviD-RiVER.part7.rar
Kód:
http://rapidshare.com/files/322392970/Top.Gear.S10E04---2007.11.04.part1.rar
http://rapidshare.com/files/322393614/Top.Gear.S10E04---2007.11.04.part2.rar
http://rapidshare.com/files/322405419/Top.Gear.S10E04---2007.11.04.part3.rar
http://rapidshare.com/files/322403883/Top.Gear.S10E04---2007.11.04.part4.rar
http://rapidshare.com/files/322396422/Top.Gear.S10E04---2007.11.04.part5.rar
http://rapidshare.com/files/322404544/Top.Gear.S10E04---2007.11.04.part6.rar
http://rapidshare.com/files/322404933/Top.Gear.S10E04---2007.11.04.part7.rar
http://rapidshare.com/files/322403298/Top.Gear.S10E04---2007.11.04.part8.rar
cz sub
Kód:
http://www.titulky.com/Top-Gear-S10E04-Botswana-Special-140879.htm
Suzuki Samurai 1300 karbec, prevedenie TANK /celoplech/, vybava TERMIT /pilka,sekerka a ine drevokazy/, environmentaly friendly: LPG
Ned, 09.01.2011, 14:40
prave to slo na prima cool, celkom som sa bavil, hlavne vychytavka ako dostat vodu z auta po brodeni :-D
http://www.zebra.lt/lt/video/TOP-GEAR-Botswana-Special.html
Uto, 22.03.2011, 18:35
