Zobraziť témy bez odpovede | Zobraziť aktívne témy Aktuálny čas je Uto, 09.12.2025, 12:44
 Top Gear Bolivia special
Registrovaný: Str, 07.05.2008, 8:05
Bolivia special
Format : AVI
Format/Info : Audio Video Interleave
Format/Family : RIFF
File size : 701 MiB
PlayTime : 1h 26mn
Bit rate : 1127 Kbps
StreamSize : 10.6 MiB
Writing library : VirtualDub build 32661/release
Video #0
Codec : XviD
Codec/Family : MPEG-4
Codec/Info : XviD project
Codec profile : Streaming Video Profile/Level 1
Codec settings/PacketBitStream : No
Codec settings/BVOP : Yes
Codec settings/QPel : No
Codec settings/GMC : 0
Codec settings/Matrix : Default
PlayTime : 1h 26mn
Bit rate : 990 Kbps
Width : 624 pixels
Height : 352 pixels
Display Aspect ratio : 16/9
Frame rate : 25.000 fps
Resolution : 8 bits
Chroma : 4:2:0
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.179
StreamSize : 611 MiB
Audio #1
Codec : MPEG-1 Audio layer 3
Codec profile : Joint stereo
PlayTime : 1h 26mn
Bit rate : 129 Kbps
Bit rate mode : VBR
Channel(s) : 2 channels
Sampling rate : 48 KHz
Resolution : 16 bits
StreamSize : 79.3 MiB
Writing library : LAME3.90.
Encoding settings : ABR
Kód:
http://rapidshare.com/files/368661864/aaf-top.gear.s14e06.bluray.avi
alebo
Kód:
http://rapidshare.com/files/326778114/Top.Gear.S14E06.HDTV.XviD-FoV.part1.rar
http://rapidshare.com/files/326779757/Top.Gear.S14E06.HDTV.XviD-FoV.part2.rar
http://rapidshare.com/files/326777891/Top.Gear.S14E06.HDTV.XviD-FoV.part3.rar
http://rapidshare.com/files/326778268/Top.Gear.S14E06.HDTV.XviD-FoV.part4.rar
alebo
Kód:
http://hotfile.com/dl/22064820/1570d19/Top.Gear.S14E06.HDTV.XviD-FoV.part1.rar.html
http://hotfile.com/dl/22065158/775f79d/Top.Gear.S14E06.HDTV.XviD-FoV.part2.rar.html
http://hotfile.com/dl/22065595/767391f/Top.Gear.S14E06.HDTV.XviD-FoV.part3.rar.html
http://hotfile.com/dl/22065846/f1265e7/Top.Gear.S14E06.HDTV.XviD-FoV.part4.rar.html
heslo: irfree.com
sub
Kód:
http://www.titulky.com/Top-Gear-S14E06-Bolivijsky-Special-149326.htm
Suzuki Samurai 1300 karbec, prevedenie TANK /celoplech/, vybava TERMIT /pilka,sekerka a ine drevokazy/, environmentaly friendly: LPG
Naposledy upravil steeler dňa Ned, 09.01.2011, 12:32, celkovo upravené 2
Uto, 06.07.2010, 20:27
Jednoznacne najlepsi special TopGearu, treba pozriet :wink:
Samurai > Jimny > Vitara
Str, 07.07.2010, 0:13
