Zobraziť témy bez odpovede | Zobraziť aktívne témy Aktuálny čas je Štv, 18.09.2025, 0:35
 Jeep JK - aktivacia a deaktivacia funkcii bez diagnostiky
Keby sa to niekomu hodilo tak tu je pár návodov ako sa dá bez diagnostiky aktivovať/deaktivovať niektoré funkcie v JK
Vypnutie zvukovej signalizácie nezapnutých pásov
/ (Turn seatbelt chime OFF COMPLETELY )
1. turn the ignition switch to the OFF position, and buckle your seat belt while sitting in the drivers seat.
2. turn the ignition key to the ACCESSORY/RUN position (engine does not need to be running), and wait for the seat belt warning light to turn off.
3. unbuckle and then re-buckle your seat belt at least three times within 10 seconds, ending with theseat belt buckled. then start the jeep.
4. turn the ignition key to the OFF position. A single chime will sound to signify that you have successfully completed the programming.
Next time you start the jeep, you’ll hear the initial fasten seat belt chimes, but the continuous chiming reminder will be turned off. the light in the dash will remain on, though.
Vypnutie ESP / (Turn ESP OFF COMPLETELY)
1. Turn jeep on
2. Set to 4hi
3. Set parking brake
4. Make sure steering wheel is centered
5. Turn wheel to the right, 180 degrees, JEEP logo should be upside down at this point - hold ESP off button for 7 seconds, you may hear a chime at 5 seconds(and ESP OFF may show up on the speedo), but keep holding for 7 seconds !
6. Turn wheel back to center then left 180 degrees, JEEP logo should be upside down at this point - hold ESP off button for 7 seconds, again, hold for 7 seconds
7. Turn back to center, and hold ESP for 7 seconds.
8. Turn Jeep off
Automatické zatváranie dverí zapnúť-vypnúť / (Autolock Doors At 15 MPH)
1. Open the driver door, sit in the driver seat, and close the driver door.
2. Turn the ignition switch to the RUN position (without starting the vehicle) and then back to OFF. Repeat this step three additional times (for a total of four key ON/OFF cycles).
3. Within 10 seconds of switching the ignition switch to the OFF position for the last time (at the end of the fourth cycle in the above step), press the driver interior door lock switch to LOCK.
4. A single chime will be heard to verify that the customer programmable toggle of the rolling door locks was successfully completed.
Steps 2 and 3 must be completed within 10 seconds.
NOTE: When toggling the rolling door locks (customer programmable), the toggle that happens will be from the last state of the rolling door locks. If the rolling door locks were enabled, after the toggle process, they will now be disabled and vice versa. There is no telltale to inform you of which state the rolling door locks are in.
Reset signalizácie výmeny oleja / ("Change Oil Boogie")
Do this to tur off the "Change Oil" message that scrolls across your OD
1. Turn the key to the Run position
2. Press the gas pedal 3 times (pressing all the way to the floor within 4 seconds)
3. Turn the key to the Off position.
Naprogramovanie nového kľúča / (Programing a new key ).
To program a new key yourself you need BOTH keys. So do this BEFORE you loose your one of them or else you will have to face the wrath of the dealership (and nobody wants that!).
This can be done with both types of keys (regular and FOB keys). Even if you have FOB keys you can get a cheap regular key for the third just so you would still have that second key after loosing one (so I've read anyway, I havent lost any of my keys permanently yet).
This is how you do it
1. Cut the additional Sentry Key Transponder blank(s) to match the ignition switch lock cylinder key code.
2. Insert the first valid key into the ignition switch. Turn the ignition switch to the “ON” position for at least 3 seconds, but no longer than 15-seconds. Then, turn the ignition switch to the “LOCK” position and remove the first key.
3. Insert the second valid key into the ignition switch. Turn the ignition switch to the “ON” position within 15 seconds. After ten seconds, a chime will sound. In addition, the Vehicle Security Alarm Indicator Light will begin to flash. Turn the ignition switch to the “LOCK” position and remove the second key.
4. Insert a blank Sentry Key into the ignition switch. Turn the ignition switch to the “ON” position within 60 seconds. After 10 seconds, a single chime will sound. In addition, the Vehicle Security Alarm Indicator Light will stop flashing. To indicate that programming is complete, the indicator light will turn on again for 3 seconds and then turn off".
5. Start your car. If it stays running for more than 10/15 seconds then you've done your job. If it starts and stops, DO NOT KEEP TRYING TO START IT! It will lock you out for 24hrs after a certain amount of attempts. And all you can do is wait, or have it towed to a dealership to have it reset. If it doesn't work, try the process again.
Str, 01.11.2017, 22:13
